Emperor-TK
Another GSSL is born today. I've had it 95% done for a few months, but finally got around to putting the final touches on it, including a new front panel, a meter light, and trimming the meter properly.
This is probably some important info, some of which is burried in the GSSL help thread, but this is what I had to do to get the unit to respond properly using THAT 2180LA VCA's:
1) 100K resistor driving neg input of TL072 to VCA CV's replaced with 122K to get proper ratios for THAT 2180LA's.
2) 2K resistor feeding meter replaced with 1K +/-5% for 0-20dB range.
Note: I tried to get a 0-10 dB range, but there wasn't enough current with the resistor completely bypassed to drive the meter to full scale at 10 dB reduction (this is what the trimmer is for that you see by the ammeter).
3) Threshold potentimeter changed from +12/-12V range to 0/-12V range to get better precision (+12 leg replaced with ground). This has the threshold kick in at about -50 to -40 dBFS with the threshold at it's lowest setting (ratio dependant).
4) Pin 4 on the VCA's are bent up and away from the IC sockets to disconect from the trimmer circuit (I'm not sure if this is nesc, data sheets have pin 4 as N.C.)
Pardon the poor pictures, I can't find my digital camera and had to use my video camera's still function (no flash).
I also ran some attenuation response curves for the unit that I compiled into an excel sheet if anyone's interested. The curves show how the knee of the compressor behaves, gentler at lower ratios and sharper at higher.
http://www.emediatransfer.com/chris/GSSL_cal.xls
