Hi All. i am compiling a master excel spreadsheet for the parts list for the 1081 project.
I will be making the master list with part numbers from Digikey and Mouser primarily. but may use others if necesarry
When i have finished the master spreadsheet it will be posted here. (someone will have to host it as i am having a terrible time getting my webspace sorted)
I have found conflicting things from the varuois sources available.
The original schematic for the 312 shows 4m7 resistors a plenty, however these seem to be listed as 6m8 on the Parts Lisrt Rev 3 found on VintageDesigns.
On that list is also various resistor tolerances and wattages.
Should I use the Tommy Rev 3 list for the wattages and tolerances?? If so Great!!
also what types to use and where. I am assuming Metal film wherever possible and the carbon the rest of the way.
I have found other discrepencies.... where some resistor values are listed as 6m8 on the rev 3 list i have found things other than that on the 312 schemat. ( I will post this all later today or tonight as i am at work now....)
i have yet to comb through the 308(306 schemat) 338 and 340... but will do so soon. these too will be in the master list.
for the Resistors Does anyone have preferences to which manufacturer to use?? (xicon, yageo, panasonic, koa etc etc...).
And likewise for Caps. Which manufacturers and types. also what tolerances would you all suggest?
more later
cheers
-david
more later
cheers
-david
