Hulk
There's an old "insider" trick you can do on the original push button 1176 - if you push in all ratio buttons on the 1176 it will create a cool compression effekt!
I'm working on the Gyraf 1176 using mnats PCB and since it has a rotary switch for the rations I only can dial in one ratio at a time - I want to make a fifth ratio on the rotary called "ALL" or something like that but how could I do that???
