second mic pre finished *pics*
ioaudio
vienna/austria
i finished my project around the ef12 tube. the design originates from the circuit i posted recently, but i got rid of the ec92 stage.
like my first mic pre i build a small case with exernal psu, i can run both pres from one supply.
some pics from the new one:
edit: changed cathode resistor to 2,2k
thanks.
the front panel is covered with the surface i´ve recycled from a loudspeaker. old stuff.
describing the sound is always difficult for me... i like it very much with bass via di input. the sound is coloured, nonlinear, thd is probably higher than in other circuits...
I like how it is built on a piece of wood.
I like the hold down wire for the ef12.
What transformer is that on the bottom left?
[quote author="Gus"]
What transformer is that on the bottom left?[/quote]
i dont know :green: but i posted pics here:
http://www.groupdiy.com/index.php?topic=9498
Very nice !
Looks like a direct box.
Balanced or Unbalanced ?
Looks like this is a easy build, simple circuit , probably great sound.
I've always found it hard to convert schematics to actual component
layouts they seem like puzzles to me. You should offer a kit/plans on the black market that would help people convert your schematic to a component layout. I would certainly get one and try this myself.
Was the Ef12 hard to locate ? how are microfonics on these ?
transformer balanced mic pre with instrument (high z) input.
finished recording an album last week, used it for snare (sm57)-very good
have to modify the circuit to use it with hot condensors, too much gain...
will update when finished...
i first found the ef 12 (flea market) then designed the circuit. i guess they are quite hard to find
Hey, I like this! See, this is what I want to be able to do, build some stuff that works! I'll get up the nerves soon to try some DIY. Oh yeah, when I do, I'll let yawl know ahead of time so you can take all your perishable goods out of your refridgerators, freezers, etc. Cause the power "WILL" go off! :green: .. :grin:
