Silvas
Yeah, i know...some of you will say "WHAT A WASTE OF RACKSPACE !!!" specially with all these 500 series modules around, but i have at least 4 good reasons for this, i promise.
1 ) i wanted it to be big and impressive looking
2 ) i wanted to use that big old TEAC meter
3 ) i needed a big, non-heating unit to put between the D-LA2A and the PM670 !
4 ) 2RU isn't an option for me. It has to be 1RU or 3RU. My local metal shop doesn't make anything i can adapt to a 2U front panel and works nice. and 1RU isn´t enougn for that meter...
It´s an Mnats rev J board, with OEP´s on both sides. "stock" unit and OEP's installed "native". Due to my choice of transformers (i got rid of a couple leftover toroids) i decided to use the PSU board that came with the main board. I used a couple 5457 Jfets instead the low leakage diodes. And, yes, i installed the 2N5457 FET's backwards at first ! took me a while to find out. Gladly, they are in sockets,as the 5457's connected as diodes.
That skull ? you know what is it.
What can i say ? it´s an 1176, and everything is as expected. So far i've used it only on a mix, great compressor.
Only issue 'm having is audio pumping when in bypass with the fastest release settings...strange. I think i'm putting a relay bypass board here.
Wiring isn't particularly pretty but it works and the baby is very quiet.
Yeah, that's me !
Next time, i'll do 2 channels in such rackspace. I promise !
Thanks Mako for such great work with the boards !
Yeah, that's me !
