Mikael-ange
Active member
Ok coolVillemoisson sur Orge (Essonne, 91)
Je suis pas loin de toulouse (dans une petite ville qui vient d'etre connu pour ca defaite contre une equipe de foot parisienne)
Should? That is one operating point out of countless others: the 120v, 100k loadline at a -1V quiescent point is perfectly valid. Also note that 220K with a 120V supply will have little output headroom running near 1mA static. The C12 operating point is a good compromise between noise, input single swing, output headroom, and output impedance.For like a 120B+, self Bias should have a 220K plate resistor& 3.8K for cathode for around -4 grid voltage for class A.
-1 at the grid would be for more like a 12AX7 or a 12AU7 on self bias.
+1 on PSU PCB’s …Any chance that these boards will be avalible again?
I had a similar problem back in the day at the very beginning of this thread, it was one of the polystyrene's had burned up, might want to take a look back in the thread to then, good luckTried with a 200k resistor between ground and B+, could trim fine to 90V, so it must be something wrong in the mic...
Thank you,I had a similar problem back in the day at the very beginning of this thread, it was one of the polystyrene's had burned up, might want to take a look back in the thread to then, good luck
You probably already know this, but for anyone inquiring, I found the safe way to install styrene is to pre tin the turret and then clip a heat sink(alligator clip) to the styrene lead, get your iron very hot, touch and go quickly as to not hang around and run the heat up into the styrene, i'm positive that is how i burned my first oneThank you,
I read your story. I will order new styrenes and see if there's a change.
All the best
bump...I ordered another pcb and parts kit from Chung, got an initial 939 site generated conformation email, haven't heard anything back for 8 days now, is Chung still in the game?
Took about 6 weeks and a few days for me to get my order (received about 2 weeks ago) which is consistent with other orders from chunger. I have recently made another order with him, so his "system" is functioning. I don't think you'll receive further communications from him, but, I can't speak for the man.bump...
Hey, Tony …bump...
