> unfortunately it is not possible to avoid matching transformers if you want a decent output.
I must agree, if "decent" is pretty big.
The maximum DC power available is 24V and 3.4K.
The audio load can be 10K, or it can be under 200 ohms. (Don't forget line capacitance.)
Right away we have mismatch. We have ~3K power supply and 0.2K load. Now, for a single-ended totem-pole amplifier and Sine wave, the average supply drain is like 6 times the load. A 8 ohm speaker-amp at full roar acts like around 50 ohms to the supply. A 0.2K load is like 1K to the supply. This means we can't use even 1/3rd of that 24V, only 8V. And the biggest steady sine we can put in 200 ohms is 2.8V.
OK, that's pretty decent.
But we like balanced output. And so we have two 100 ohm loads. We have two 500 ohm DC drains. We have 250 ohm DC load on 48V and 3.4K, or 3.2V to work with. We'll get 1.1Vrms per side, 2.2V differential.
That's above the maximum level I ever hope to see off my hottest mikes. But I no longer do "loud". A full orchestra in the third row is nothing like close-mike rock-n-roll, or even some singers in the near field.
The above leaves nothing for the head-amp. The headamp or driver may need substantial current, which directly hurts the maximum output.
The now-older AKG 414 (non-TL) uses a single-ended output coupled through a 1:1 transformer, and I think is rated for 100 ohm load. I did the math once, and thought that it could hold its rated Max Output at that load. It has a good cap, it would surely pass the rated max level as a transient; or with a higher (and more typical) load above 300 ohms or so.
There is a -10dB pad, and with that engaged it seems to be ample up to unmusical sound levels.
So it is barely possible to get "decent" output. But there is a LOT of engineering in there. More stuff inside the mike than the preamps I use.
Interestingly, a simple 800:200 or 600:150 ohm 2:1 transformer gives a near ideal power match between 3.4K Phantom and 200 ohm loads.
Ah..... the "6X rule" assumes class B/AB output. For pure Class A push-pull the factor is 4, and you can't cheat with transient peaks. Class A SE really sucks.
Rossi is right. Old-spec 2mA, new-spec 10mA, all jacks; real-world does not know specs. If your mike is fussy, you WILL find situations that make it unhappy. The AKG is un-fussy: internally it runs on 9V and idles 2mA. The regulator dropout is below 12V, and it is rated to run full-spec on P12 which IIRC is 12V through two 680 ohm feeders.
