tarandfeathers
Member
I recently built an 8 channel mic pre that uses Lundahl 1517s on the outputs. At present these are only terminated by whatever I plug the outputs into. On some of the channels I get a lot of interference (sounds a bit like AM radio static) on the last step of the gain switch. I'm wondering if this is some kind of ringing in the output transformer, as it seems to be significantly improved (though not completely remedied) by a makeshift RC termination (560R in series with 22nF). Most of Lundahls datasheets list a recommended termination but not for the 1517. Anyone know what the right values to use would be, and/or if doing so would be likely to fix the problem I've described?
Daniel.
Edit: I should add that the transformers are wired 1:2.
Daniel.
