bluebird
So here is a schematic of the things I did to the PRR varimu.
I used the original circuit board layout here:
http://www.diyfactory.com/projects/diy12au7comp/diy12au7comp.htm
when I first built the stock 12AU7 version it sounded nice but I wanted it to do a little more so I started copying some things from the UA175 which used the 6BC8.
PRR suggested using the 6ES8 early on.
So I changed the plate resistors to about 4K and found out the interstage TX for the 175 was an A19. I figured 15K on the plates was a good idea.
I don't know if the 25K dual pot in front of the input transformers is the best place for attenuation but it works for me. someone might want to try it after the input transformer wipers into the tube grid.
Another improvement would be NOT to use the shunt method of volume control for the 990 opamp. A 100K pot could be used instead of the 100K resistor in front of the 990 for a wider range of volume control.
I ran the 6ES8 heaters in series (cut a few traces on the board) so I could still use 12VDC.
I ran the 990 from the same +/- 15 volt power supply used for the other chips. Cinemag input and Triad interstage transformers.
I used a vintage 1ma meter that had VU graphics on it.
6BC8 will also work in this circuit.
