there's nothing different going on in a 1272 than a 1073 below about 40 something dB
Well, in concept there's not much different, true, but to avoid confusion, of which there seems to be much regarding a 1272 as a mic preamp, 1272's were generally fixed gain on both stages with a pot to adjust level between preamp and output stages.
The typical mic preamp conversion is to add a 2-stage switch to contol a pad in front of the input trafo and the gain of the preamp stage. The output stage generally remains fixed. It is easy to make a 1272 mimic pretty exactly a 1073-type preamp in this manner, up to 50dB of gain. After that your gonna have to increase the gain beyond what Neve did.
Tim's N72 is unique among the various commonly found '1272' clones in that it uses the Neve approach of using a 3-pole gain switch to control attenuation and two gain stages. Splitting the gain duties between both stages definitely changes the sound, apparently for the better according to comments made here and elsewhere. Neve used 1272's for talkback mic preamps with 70dB of gain by increasing both stages.
FWIW, I would argue that you could get a little higher gain from a 1272-type design and not really violate Neve's guidelines by dropping the lowest gain-set resistance for the preamp stage down to 91-ohms, which gives around 31dB total from this stage instead of the 28dB of the 120-ohm that is typically used here. Neve used a 91-ohm resistor on an identical preamp section for the third stage in the three-stage mic preamps. Beyond that your requiring more from the amps than Neve used in this application.
If you still need higher gain and want to maintain excellent LF response, increase the caps coming off the power rails (connected to pins M and N) to higher values. Neve used the highest values they could physically fit in these positions, typically a 470u or 640u or a couple of these in parallel if space allowed. Caps are now much smaller, so you can increase them easily. I use 1500u to 4700u depending on space available.
JC
