Nice work, Dagoose.
It strikes me that crosstalk is part of what one wants to mess with ITFP when employing M/S processing. One wouldn't insert it and
do nothing with it so worry over a crosstalk spec seems of practical worthlessness, unless it's truly horrible.
For those curious about the specifics of Wayne's final design, I'd start here, on page 18 of the design thread:
http://www.proaudiodesignforum.com/forum/php/viewtopic.php?f=6&t=112&start=170#p2714
block diagram here:
http://www.proaudiodesignforum.com/forum/php/viewtopic.php?f=6&t=112&start=180#p2917
I'm reading better than -90 dB for stereo crosstalk, which is within 6 dB of the absolute noise floor of a CD. I recall that being roughly 50 dB better than the average noise floor of vinyl, and 35 dB better than the noise floor of tape sans NR. All at a very low price, and with nearly no hassles. Approval from Bob Katz and Paul Gold, to boot. One can easily note the signal path of the M/S encode/decode is three IC's in total, if one ignores the balancing IC's, which are present as the board is laid out to cover everything up to and including stand alone operation. If you include the basic circuit within another design enclosure, without the in/out IC's, it becomes very short, straight, and elemental. Simple, elemental, minimalist, inexpensive, elegant, and as foolproof as any option I've seen. I think one would be a fool to dismiss it's capabilities without trying it, especially while chasing any more esoteric and expensive implementation.
It only takes a very small mistake with passives to end up with much worse crosstalk; right down to the wiring on switches.
I like seeing your approach as well, Twenty Log. But those $10 resistors start to hurt me quickly. I think the devices I will insert into any M/S matrix will send all reasonable attempts at stereo precision to hell anyway, and will almost always have their own imprecise gain controls. I expect to have to find unity, or any other point, by measuring tones.
I am still using an encode/decode matrix made of Jensen transformers, which is also tough to beat, if one is inclined to feel spendy, and I don't do anything of any noted musical precision anyway.
Bonus prize to identify both quotes.
but, like, it's got electrolytes!
noise reduction?! Why would you want to reduce the noise?!
