dagoose
I built a passive, relay based masteringconsole some time ago and i always wanted Mid/Side and so i took out the iron and modded it to the console of my dreams. ;D
Is has 6 inserts, 3x compressor, 3x EQ with flippable order (comp>eq eq>comp) by the push of a button.
The inserts are selected by 2x 3 steps lorlins powering relays.
Both eq and comp have a dedicated hard bypass.
Then we have the mid/side option (wayne kirkwood ms matrix) that can be inserted in the EQ path or compressor path by the push of a button, so ms eq or ms compressor all with full bypass, order etc functionality! (it has 16 relays just for the insertion)
Ofcourse it is fully balanced all the way and inserts are done with 24 6,3mm jacks in the back of the panel, in and out are XLR's.
The psu is external, 12v for all relays and + and - 18v for the MS matrix, both have their own tranny's and psu.
In total it has 63(!) relays to make everything work, all done on veroboard! 8)
All settings are visual by the color of the buttons, they have 2 color leds so when red it is in bypass and when green (comp) or yellow (eq) is lit you can see it's active, same for MS, green is comp, yellow is ms eq.
The front is done with lasertran but i wll probably go for mittelbronze schaeffer panel soon.
It is totally clean and reall works like a charm and i'm really proud of it!
ok... time for some pics...
