DIY Gate
Chuck78
Columbus, OH
I did some searching on the site but couldnt find anything. Was wondering if anyone has designed a gate?
Thanks in advance.
http://www.groupdiy.com/index.php?topic=1640&highlight=diy+gate
:green:
just kidding
try this:
http://www.groupdiy.com/index.php?topic=366&highlight=diy+gate
it's not much but maybe we can change that.
Here's what I found till now - the PCB layout:
http://groupdiy.twin-x.com/albums/userpics/10004/Gyraf_NoiseGate_Layout.PDF
I'll keep searching for the schematic..
This gate is based on a FET attenuator. It has key input -filters and -listen as well as hard bypass. Audio only passes FET and one 5534 - thus working unbalanced, but with very little sonic side-effects.
Controls are threshold-attack-hold-release-HPF-LPF-keylisten and bypass.
Action is indicated by a single red/green LED (that works pretty well, if I may say so..)
Jakob E.
wow! I was going to design a simple fet gate (without the SC). but now...since jakob did the work allready ...I can safe the time for something else :green:
thanx Jakob for sharing this!
steff
Perfect Jakob! :thumb:
Thanks a lot!!! Hope you find the schematics.
Just womdering... anyone ever considered to do gates with solid state relays (MOS switches) or something like that ??
:sam:
Fabio
[quote author="Bauman"]
[/quote]
No. Even though gates in-theory are on/off devices, you need to adjust their opening/closing times in order to use them for audio - which means that you need controlled gain, not simple on/off.
Jakob E.
I´m ok with this, but what about to use it to control the gain of and opamp
like the usual fet gate circuit , better than a fet for that?
Just curiosity here, not pretending to reinvent the wheel... :green:
:guinness:
Fabio
Some questions regarding the Fairchild gate... Does anyone see a problem if I just use a regulated DC supply (external) and tie it in across the outputs of the bridge? I suppose It may be simpler to just pop the diodes out, jumper across the right ones and use the connector.
6.3v? How critical is this do you think? I have a decent linear 5V supply that I'd like to use.
Kevin.
