[quote author="kato"][quote author="clintrubber"]
Why not ? (if the PCB is not too heavy in total or could nechanically be decently supported)... [/quote]
It does have a fairly heavy input transformer onboard. Seems like too much weight to be pulling on the xlr solder pins. I find it easiest to drill XLR holes without regard to perfect alignment with a PCB. Maybe I'm too sloppy for pcb mounted XLRs.[/quote]
Definitely better then to have wired connectors, you don't want to risk problems later on (hassle to fit in a bad fitting XLR when in a hurry, putting strain on the connections etc) for some more ease at the assembly-stage. Hey, I saw even my Beh. MDX2100 Composer neatly uses some wires from PCB to connector :thumb:
