matta
[quote author="Igor"]
Add 1.6mm PCB and some mm down the pcb to avoid shorts to case.
So, right answer-no
Only way to mount Carnhill's or StIves in 1RU is to lay them down
on isolation pcb's and hookup with wires. As in 33609.
See this tread:
http://www.groupdiy.com/index.php?topic=26218&postdays=0&postorder=asc&start=345
(thanx to promixe for photo).
Regarding Sowters....will see what is possible.[/quote]
I expected as much... Igor, since you were asking for suggestions... and if it a> is not too expensive, b> not too much effort... why not have the little transformer PCB that one can solder the Carnhill iron to and have the pins terminate at a molex header than can be attached to the header on the main board... a more elegant solution? Though more costly...
Matt
Carenhills are 38mm min height...we have 40mm inside rack...With the single channel unit will the Carnhill transformer lie horizontally? I don't have one with me now, but just wondering if they are not too tall vertically to fit into a 1U rack?
So, right answer-no
See this tread:
Matt
