peter purpose said:;D
Draw the bleedin thing out then....!!
The one I'm using? It's the same as the diagram but instead of grounding, it goes to -16V.
And 1k and 4R7 resistor values. Input and output caps.
How d'you sort it?
onlymeeee said:How d'you sort it?
peter purpose said:onlymeeee said:How d'you sort it?
I crosed Dan Kennedy's palm with gold.
peter purpose said:You only showed me a bit..!!
peter purpose said:Still got your name on it, but only if you explain the intricacies of the circuit.
PRR said:> a few early warranty returns
Hmmmm. It does not dis-engage for several seconds after the rails slump. One diode or a re-shuffled resistor, or diode and added resistor, would change that. Ideally it would cut-out like cut-in: at ~~28V, as power starts to fail, not after it has quit.
PRR said:There are voltage detectors for mini-brain systems which will drop a "Ready" line when 3.3V gets to 3.1V, to stage an orderly shut-down while there is still enough juice to think with. Ought to be able to shim that by factor of 9 to work here.
PRR said:There are voltage detectors for mini-brain systems which will drop a "Ready" line when 3.3V gets to 3.1V, to stage an orderly shut-down while there is still enough juice to think with. Ought to be able to shim that by factor of 9 to work here. But the datasheets and pinouts always baffle me.
