[quote author="Martin"]In your pictures I noticed you are running very hi impedance wires in spiral shape down to the little PCB, might not be optimal... [/quote]
thanks for the suggestion, I'll straighted the wires up and I gained something on the noise floor.
this is the power supply I am using:
I have pretty much used what I had ready available at home.
the two trafos I am using for the B+ gives 300VDC after the bridge diodes and each >10uF 3K9< cell drops the voltage by 5 V (not much I will increase the value of the resistor as to get 200VDC at the output of the power supply).
there are poly caps across each diode on the bridges (10nF on the B+; 4n7 on the heater).
*I still get hum in the audio chain and I wonder:could the heater supply cause hum in the audio path?
*I have used an LM317 to stabilize it, is that alright or shall I use something else?
*how do I see how much ripple I get from the B+? my oscilloscope will fry if I stick it to the B+ directly...
Any comments would be much appreciated.
PS thank you analag, the mic is just A-M-A-Z-I-N-G.. we are prefering it to our M149..despite the hum.
Best
Mattia.
