can you measure the outside diam of the capsule it looks more like the 32mm ones I have seen. The samsom cl7 I worked on and superlux capsule pictures I saw had plastic hold down rings.
Removing the mesh(s) change the sound the problem is it would be hard to add the mesh back, it is possable the grill is a better design stock in the ADK than the nady,apex ones.
I would try foam at the base of the capsule mount plate first.
The CM-2461NiCo is built so it does not need the shielding an E I core does, will it fit without the stock shield?
