I intend to mount a cardioid-only U87 circuit inside of 103 body,without hi-pass or sensitivity attenuator.View attachment 128980
Well, all my 103 shell compatible PCBs are dreadful at hiss
Since all my capsules are RK87 it would be better if they were not 103 tuned circuits but of course I'm open to modifying them
My attempts at point-to-point over the years ended up in either tears or escaping magic smoke so I would prefer something more permanent...I intend to mount a cardioid-only U87 circuit inside of 103 body,without hi-pass or sensitivity attenuator.
I haven't designed the PCB for the through-hole parts yet, it's possible to make it point-to-point, something like:
https://groupdiy.com/threads/u87-clone-from-recycled-parts.86367/post-1129084
Well, I started a clone of the tlm103 circuit a while ago, it sounds great, but I was too lazy to design a PCB for it with through-hole components.My attempts at point-to-point over the years ended up in either tears or escaping magic smoke so I would prefer something more permanent...
I tried the OPA Alice round pcb over at pcbway but they're asking 40usd for the boards. Ouch!
I'm actually perfectly fine with SMD components, I have been doing SMD for years. Shoot away with SMD if you would be so kind to help me out.Well, I started a clone of the tlm103 circuit a while ago, it sounds great, but I was too lazy to design a PCB for it with through-hole components.
I used to make my own PCB, by hand, by corroding with hydrochloric acid and perhydrol, but I became comfortable, I don't have much patience anymore and then I always end up with fast point-to-point constructions.
Anyway, you can use other types of boards, convenient, cheap.
If you like working with SMDs then you can modify PCB that you have tested and are not happy with, either they have high inherent self-noise or an inappropriate sound for the capsule used.I'm actually perfectly fine with SMD components, I have been doing SMD for years. Shoot away with SMD if you would be so kind to help me out.
At this rate I might redo the OPA alice round pcb but with SMD parts... PCBway's pricing is over the top for X cut
I have designed PCB's that were only 1.25"-square, had 8-layers and had over 200 "0201-sized" SMD capacitors and resistors on both sides for The Department of Homeland Security "covert intelligence-gathering and surveillance" projects, should you need any assistance.Shoot away with SMD if you would be so kind to help me out.
If you can get or if you already have this OPA "Alice" PCB, I could "Reverse-Engineer" it for you. Or, if the GERBER and N/C Drill files are available, I have a program that can modify the files for you as well.At this rate I might redo the OPA alice round pcb but with SMD parts.
Dont know why I didn't think of that...If you like working with SMDs then you can modify PCB that you have tested and are not happy with, either they have high inherent self-noise or an inappropriate sound for the capsule used.
Have you tried drawing the schematic and then finding a suitable de-emphasis mod for the RK-87?
It seems to me the most logical solution.
Is this a Shoeps circuit without de-emphasis?
The issue is that OPA Alice https://www.pcbway.com/project/shareproject/OPA_Alice_Microphone_round_PCB_cc6947c0.htmlI have designed PCB's that were only 1.25"-square, had 8-layers and had over 200 "0201-sized" SMD capacitors and resistors on both sides for The Department of Homeland Security "covert intelligence-gathering and surveillance" projects, should you need any assistance.
I also own 2 - TLM-102's, but I'm not taking them apart!!!
In the TLM103 audio circuit, both jFETs are N-channelThis pile of shit is definitely a TLM103 I think. But extremely bastardised.
No 60v to start with. No P ch fet both are "2SK170" if those are even not remarked 2SK30 to start with
With the information contained within the attached files, there is enough here to "Reverse-Engineer" the PCB. The ONLY piece of information that isn't listed and/or shown anywhere are the mechanical dimensions of the PCB itself and the hole-size and location dimensions of the various connector and mounting holes. With all of that, a new and "original" PCB could be designed.The issue is that OPA Alice https://www.pcbway.com/project/shareproject/OPA_Alice_Microphone_round_PCB_cc6947c0.html
in any guise is locked behind pcbway
I see. Read the direction wrong but still, it's nowhere close a 103 given a 103 has 60v on the capsule, this.... who knows.In the TLM103 audio circuit, both jFETs are N-channel
https://groupdiy.com/threads/neuman...est-affordable-replacement.85985/post-1136407
I used a simple classic DC/DC converter with a BJT for the testsI see. Read the direction wrong but still, it's nowhere close a 103 given a 103 has 60v on the capsule, this.... who knows.
What capsule do you use? RK-87?I got a design in for a 103 shaped board based on the OPA Alice (and P48 biasing) that i'll be testing
May add a 60v inverter board later on
A collection of either CK12 or RK87 capsulesWhat capsule do you use? RK-87?
RK-87 needs high-frequency attenuation.A collection of either CK12 or RK87 capsules
I am aware of that, I'm gonna give it a shot first then modify some HF mods if i need toRK-87 needs high-frequency attenuation.
