For Sale *More Vtg Japanese mics (Toshiba, Fostex, AIwa, Matsushita)
ravachol
Ireland
Toshiba Type B ribbon mic
Top of the line; very hi-fi, precision engineering; solid.
This one needs re-tensioning and a cable. Comes with a very nice hard case - Canare Star Quad and a Neutrik XLR connector incl.
€950
Rare Matsushita Condenser Mic
No model number found.
Beautiful craftsmanship: capsule looks the job. Works and sounds great. Unfortunately, a ring has come loose on one of the mounts; a spot weld or a flash weld should make it right. It’s usable in its present state —it’s almost imperceptible but not ideal for proper
€690
Fostex M-88RP
Bi-directional printed ribbon mic
€745
Peak technology: subtle but takes high SPL. This black version is from the initial limited run.
AIwa VM-20 ribbon mic
€850
The last in the line of high-class AIwa ribbons. Pristine condition. Tested good; needs a new cable.
A length a fresh Canare Star Quad and a Neutrik connector will be included —as well as a velvet sock (Toshiba brand) and a hard case (from an AIwa VM-15).
National (Panasonic) WM-400
dynamic mic, not fragile
€260
-Rare to encounter out in the wild, Classy Japanese design, super solid build; comes with measurements and a proper case
-Performs something like a cross between the Sony C-350 and the Sennheiser MD-421
Matsushita VM-1 (Prototype?)
Large ribbon, massive magnets
€400
The model section on the badge is unstamped. Dated 1952. Heavy. The ball joint mount needs a bit of fidgeting as it mostly slips.
Ribbon looks OK but it’ll need re-tensioning. Comes with a beautiful wooden case.
Vesta RV-1 Spring Reverb
€430
Pure dubby goodness w/ EQ and limiter. 120V
DBX 1024
half-rack buffer/isolator/interface
€85
-Ready for anything.
-This one breaks my heart for some reason; it’s very definitely over-engineered but it makes no sense to hold on to it since it’s 120V only (no European version was on produced).
Arnold W1390-M active fader
€150
-Danner format, Tuchel connector, Neumann W444 replacement, +24V
-Clean, excellent condition, smooth action
-feels very solid with a pair of chonky Pikatron transformers inside
Shipping from Ireland, plz take that into consideration. Feel free to PM me for an exact quote to your location.
No question will remain unanswered. I’ve been buying/selling gear for many years and I always strive to maintain a copacetic exchange.
Lastly, I’ll most likely add a few more random items to this post so stay tuned. Cheers!
National WM-400
Vesta RV-1
Arnold W1390-M
Vintage Matsushita ribbon microphone
Big and beefy, dated from 1952
I also have a lovely vintage AIwa matching transformer 600:50k
that would suit this mic handily.
+€30
AIwa VM-20
Fostex M-88RP
National (Matsushita) condenser mic
with its lovely Samsonite-style case
