ChrioN said:The correct resistor is most definitely 4.7k, not 12k.
regularjohn said:ChrioN said:The correct resistor is most definitely 4.7k, not 12k.
Forget using resistors. Use a 5K trimpot and you can calibrate it perfectly.
ChrioN said:The behringer meters is far from accurate. I would stick with a simple resistor.
