drpat said:...more like building a fake sports car and modifying it to something different before it even leaves the drawing board.
desol said:...if it were to be 'different', I would rather have more of the eq's in a smaller format, because i have lots of preamps.
Biasrocks said:desol said:...if it were to be 'different', I would rather have more of the eq's in a smaller format, because i have lots of preamps.
If you look at the schematic, you'll see that the line input bypasses the transformer and goes directly into the first gain stage.
Mark
MikoKensington said:I don't know if I'd put the PSU on board. Is the 1RU version two channels? It might be nice to have them as individual boards per channel. That way you could configure them vertically if desired. To fit a few in a tall rack case, or to make a small sidecar mixer.
strangeandbouncy said:Hi,
as a current owner of several original helios modules, and a former owner od several other types of Helios modules, both active and passive eq's, I suggest that going in and out un-balanced is a good idea. I have tried several different trannies in and out, and I can honestly say that they sound best un-transform(er)ed. They sound loads better imho going unbalanced Line-in than Mic in padded. Just give it a try if you don't believe me. Strange, since the mic pres are pure sex! I only have modules with the tiny Beyer trannies at the mo, but I have had Lustraphone, and also some big Sowter inputs on my stolen Active 3 band eq's.(If it was you that stole them, I am coming to get you, and it is going to hurt quite a lot when I find you . . . . ) My life is NOT the same without them.
Let me know if I can help!
ANdyP
