alexc said:Yes please! What you said
Totally agree - I prefer the relay method for sure. Much more civilized 8)
Oh, and by the way, there will be an EQ in/out switch.
ruffrecords said:alexc said:I'd like to see an EQ bypass switch if possible.
Also, pushing the boundaries perhaps,
but a HiZ DI connector to grid would be of great benefit.
Just something simple so those who wish to do so can wire in
a switched jack which interrupts the signal to grid and replaces with HiZ DI signal.
Or if really adventurous, with a relay and additional front panel switch position.
Something like this would cry out for at least a few direct injected instruments.
Great stuff
Until the other day it did have a HI-Z input via a relay! I don't like conventional HI-Z inputs that are switched by the jack socket because it means the mic signal from the input transformer secondary has to travel all the way to the front panel jack socket and back again. This part if the circuit it the most sensitive to external interference and I prefer to keep it as short as possible. In the original design I had a relay right by the transformer and the first tube grid so a HI-Z input could be switched in but the transformer to first grid length was kept small. Anyway, because this was turning into a mixer I took out the relay a couple of days ago. Looks like I need to put it back in again!
anjing said:Very nice project i have been following the poor men's version with great interest!. When this becomes available would it be in the eurocard format? Do you have any plans of making it expandable putting to units toghether making it 16:2?
alexc said:What does '14HP' width refer to? Is this a 'euro' thing ?
I am guessing the tubes will be mounted in sockets, vertically off the pcb?
And the eq knobs/switches also mounted directly off the channel pcb?
Just trying to visualise the thing ;D
bieckmusic said:Awesome Ian, super excited about the aux sends!! I want to start building up a stock of transformers, so I don't have to buy new sowter transformers, which once you convert the $, are super expensive.... Time to start looking at ebay, etc. Do you know what type of transformer I should be looking for at this stage, or is it likely to change?? I'd like to get a few nickel, and different metal transformers kind of like the shadow hills pre's.
best, and thank you so much for all of your hard work!
greg
bieckmusic said:Hope I'm not also pushing the boundaries, but would it be difficult to add a solo feature to the mixing configuration, if one wanted? I imagine mutes would just be an on-off switch in front of the fader and not difficult to add. I'm thinking the solo would be difficult and not 'EZ' because it might need an additional buss, a 'solo' buss, that would get activated when a solo button was pushed. Adding a lot of complexity... Just thought I'd mention it. Sorry to be a bother...
greg
alexc said:Just wondering,
How easy is it to make a bussing cable for the 32way connector here?
Would it be a ribbon cable with connectors 'press fit' along the length
or
Would it be a set of separate wires soldered to the back of a connector then onto the next connector in the string.
