Well, I finally got some more bench time with my Fabio 1272 boards and thought I'd share a couple of things. First, I've got it hooked up on my
ProtoPanel thing for ease of, uh, prototyping. I went kinda crazy with front panel controls just to see what was useful. I took some of rascalseven's ideas and combined them with the JLM simple mod and hotrod and ended up with four gain adjustments.
First there's a 5k log pot attenuator (from rascal and JLM simple) after the input iron. Then there's a 12 pos first stage gain control switch (standard 1272 R values), then there's the half-fader (JLM hotrod), and finally there's a 5 pos second stage gain switch. I'll post pics later.
Anyway, recall that I had top mounted my relays, which turns out to be wrong. But Fabio came up with a simple fix--reverse the protection diodes and swap relay pwr and gnd. Did that. Well, guess what? No switchy on the input selection. If the switch was set to mic when the unit was powered up it would be fine. Then I could switch to Hi-Z <click>, but it wouldn't switch back. Checking the coil voltage on that relay I see 4.08V when it should be 0. WTF? Tracing around the board I found the problem. I had installed the "auto-switch" option thinking I might use it. Well, when you swap the realy pwr and gnd, which also power this little piece, no worky. Wrong polarity on Mr. transistor--he's always on and won't let IN_CTRL go to 0V.
Since I no longer plan to use the auto thing, I just snipped the transistor out and now all is well <clickety-click>. So, if you do what I did with the top mounted relays, you will either need to leave that transistor (QSW) out, or figure out how to set it up with an NPN switch somehow.
While I was tracing around looking for solder bridges at the relay itself, I noticed that I had Vcc on several input pins. Huh. That's not right. Those are the Hi-Z feeds... There's an easy to miss link (jumper) that connects the Hi-Z Gnd to the main circuit Gnd. It's labelled SE2 and, well, it's important! Floating gnd on the Hi-Z active buffer kinda makes it hard for those active devices to work.
So there you go...a couple of troubleshooting tips for this project. Now I need to test it with some real audio. Tomorrow...
A P
