Hi Guys!
I'm actually building a G7 and even though I understood, that I need to connect all Ground traces in the microfone, I still don't get the point.
Looking on the schematic I have following ground wires: heating 0V
Pin 1 Ground
Chassis Ground
But where do I have to connect those traces, directly at the 7 Pole socket on the mic? If so, why do I have to take a 7 pole wire, if I would need only 5 with all the Grounds connected.
Actually, I have a 7 wires + shield mic cable by sommer cable...where do I connect the shield anyway? On "normal" XLR Connectors, the shield acts like the ground wire an is both connected to pin 1 and to the chassis conecting pin...
Moreover, In the Psu Unit, I have again two different Grounds to different wires, but why seperating them, when they are anyway unified in the mic?
And what about the safety Ground from the 230VAC Wall to the PSU . If I connect the signal ground to all the mentioned wires in the mic, I get a hum loop, right?
Sorry for bugging guys, but I'm really getting headache over this and I need some help... :?
Greets, Stefan
