G
Guest
Guest
[quote author="clintrubber"]
Or as an example: you find a bag with 47uF/50V caps but need a 100V rating. Just use four to get one cap of 47uF/100V: put two times two in // and put these two pairs in series.
BTW: coils behave like resistors w.r.t. the series & // thing:
(value of) L_total = L_1 +L_2[/quote]
And the downside is that it is going to cost you an arm and a leg for the Elnas
BTW - I spent a 100 euros at Audio Cube on Silmics and Cerafines
You can get carried away sometimes
Sure there is. To make a higher voltage part from caps with smaller ratings simply put them in series, but you need to use caps with double the uF's each.So there's no way to increase the voltage handling of a capacitor by using double parts.
