Gssl help - I might have messed up!
MarcOliver
New member
Hi guys.
I rarely post in here so if I am posting in the wrong forum I sincerely apologize.
I have a Gssl, and what happened was:
Plugged it in and found out that one of the channels were phase reversed.
The unit is connected via XLR-unbalanced Jack, on both in and output.
The original pots I bought for makeup and thresh were the wrong shaft size so I changed them for a pair of mono 47k pots, and now not only has the unit got very VERY low volume, even with makeup cranked up, and it will only work on one channel.
sice I haven't touched the wiring on I put and output I am Affraid that it might be because I bought "mono" pots that it only allows one channel to go through, and maybe that causes the low volume aswell.
Am I making sense? Can this be the problem? If so has anyone got a proposal for two pots that fits?
Ps. This is my first build, so I'm sorry any stupid questions.
Every bit of advice is recieved with gratitude
