ioaudio
if jacob & gustav is ok with it, - i´m ok with it!
i will provide the layout file for everyone once it´s tested.
essentially it´s a metal bracket, some screws, some 1/4" standoffs, some nuts & the frontplate. there are a couple of DIY 500 sets around, showing how it could look like.
bear in mind, that the part of the bracket facing the front plate should have the same drillings as the front, and it should align pretty well, so the leds can be mounted properly. also decicions have to be made how to make the stereo link, and how to mount&wire threshold, makeup, bypass and mode.
so there´s some work left to do.
the main pcb is 149mm x 117,2mm (5866.1mil x 4614.2 mil) with the connector included. the metal bracket should be 150mm x 117,2 mm, angled part ~36mm x 117,2mm
i wanted to keep using the lorlin for cost reasons - makes the front layout a bit limited but should work.
:sam:
:sam:
