Hi all...
I have been fiddling with a simple preamp based on the V72 in the first stage and a SRPP stage as the driver.
I would like to add a simple passive RC HPF between the two stages but I seem unable to get it to work as wanted... or do I need a hearing aid??? . What I want is the HPF to have a calculated roll-off of 106HZ and 55Hz (the two 15nF caps with the 100k resistor) but it seems like the HPF is affected by other caps and resistors and I cannot see how.
I am also concerned if the Pot with 100k actually would create a "variable" HPF in which I have no intrest.
Anyhow I post a schematic of the two different solutions that I have been working on.
In the A I wonder how the suggested R1 and R2 would isolate the HPF from the EF86 coupling cap? And also if I could use the R3 to add some resistance to get 100k in total with the parallell 1M (R4)?
I also wonder how C1 and C2 would affect the HPF... is the C1 just in series with the two 15nF?
In the B schematic I think if the C3 and R4 would be isolated from the HPF as a single RC filter and the HPF with R3 as a separate RC filter?
Any advise would be very much appreciated.
/John
/John
