[quote author="enthalpystudios"]I just cant for the life of me find where I bought mine (and the price was WAY right, whatever it was), but the model number is P22WP, and is not printed on the mackie versions.
[/quote]
I think they were on sale here:
http://www.apexjr.com
P22WP is some OEM model propably, though if you get datasheet it may be possible to find close enough Vifa replacement. Mackie propably have them too.
E: Found the old pages, here are the specs:
Vifa P22WP-01 8" woofers OEM marked. Used in the Mackie 824 monitors. features: 30 oz. vented magnet, 35Hz - 4KHz, Mineral filled poly cone, butyl rubber surround, cast mannesium basket, 1.5" voice coil
TS: Fs 29.5Hz, QMS 2.20, QES 0.31, QTS 0.27, Vas 77 l, Re 5.8 ohms, Sd 235 cm2, Rm 2.5, Bl 10.2, Md 29.5 g, Xmax 6 mm $27.50 ea or case or 6 for $150.00
For a project using the P22WP-01 check out this link from monster-hardware.com
Source: http://web.archive.org/web/20040406220240/http://www.apexjr.com/speakerstuff.html
I think you can't find better replacement than this unless you get original somewhere (maybe somebody who bought them from ApexJr could sell you a pair):
http://www.madisound.com/cgi-bin/index.cgi?cart_id=6034200.9976&pid=1362
This may though be just a little bit too small in dia, maybe the PL22WR driver (though with paper cone) might also do.
