[quote author="tk@halmi"][quote author="dale116dot7"]
Really, for a preamp you would ideally be able to adjust the op-amp's internal compensation against gain. A designer here is wise not to use the Av = R1/R2 formula for gain - that's the simplified version that doesn't really work if the gain is high. A nice op-amp for this is the AD797, it allows the designer to decompensate the amplifier.
[/quote]
I have been entertaining this idea for some time. Using a double pole rotary switch for gain control one circuit could adjust Ccomp and the other Av. This way at higher gains the amp would be gradually decompensated as needed.[/quote]
Douglas Self "entertained" the idea in the extreme some years ago:
http://l2.espacenet.com/espacenet/bnsviewer?CY=gb&LG=en&DB=EPD&PN=GB2242089&ID=GB+++2242089A++I+
http://l2.espacenet.com/espacenet/bnsviewer?CY=gb&LG=en&DB=EPD&PN=GB2208053&ID=GB+++2208053A++I+
For those few that miss it :wink: just scroll thru the pages with the arrows up top or pop on the Biblio,Desc,Claims etc buttons.
Regards,
Tom
[/quote]
Regards,
Tom
