Modifying PRR Vari-Mu Compressor for +4dB Operation
BUT- ass PRR says you might need to double up on the driver if you need to drive a real 600 ohm load. If you are going into 10k converter inputs and just need some extra level you should be OK.
Check out the GSSL tail end for a simple drive circuit. thats about as easy as it gets and you can breadboard it easy or use the self-etch pdf for the GSSL and just snip out the part of the circuit you need in photoshop and etch this.
Kelly
