Hello, I am currently building my first microphone. It's a "Pimped Alice" by Jules that can be found here: Modify a Cheap LDC Condenser Microphone.
The circuit was made on perf board with a JLI-3412 capsule. I have made a few modifications by swapping the PF5102 for a 2sk209 (I used a lsk170B in the spice model), adding a treble control, and 0.47uf input capacitors with 10k resistors.
Spice model:
(R16 is a trim pot and R3 + R2 is the bias trim)
The circuit seems to work as intended in Spice, and when testing the voltage at certain points, everything seems to be fine. I am reading 3.1V at the source of the JFET, 9.3V at the drain of the JFET, 12.47V right before R5, 32.2V at the collectors of Q1 and Q2, and the bias circuit seems to be working as intended. I believe all the grounds are wired properly, and the capsule has been tested in another mic. These voltages seem to correlate with the spice model.
Despite this, when I connect the capsule, I am not getting any signal from the mic. There is no noise or hiss, just a completely silent signal. If anyone has anything I can check for or need to post more information regarding the build, please let me know. Thank you very much, and have a great day.
-Sky
Spice model:
-Sky
