davoux
Active member
Thank you so much for your help. Here is what I did while I was waiting for response. I went through all my old resistors and found a 220ohm 2w resistor. So, Replace the 2.2K with it. I figured it would disipate some heat before the LM317 to help. When I did this, the volt drop was 4V across it, from 77 to 73v. Then when I set the voltage from the LM317 at 50V, I end with 49v going to the mic input section. Approx. 1v is dropped over the series resistor and I end up with 48v that will go to each 6k81 resistor. I let it run for about 10 min. and then felt the LM317. It is only slightly warm about the same as the LED. Using your equations, I calculate the LM317 is dissipating about 1.15w. So I will get a cheap heat sink and see if it holds up. Looks good for now.
Thanks so much, John
