mitsos said:From brief looking online, seems the 6cg7 is pin compatible with the 6n1p and 6n6p russian tubes... I think I'd be in for 1-2.
But if I may make a small recommendation, could you leave a bit more breathing room for those caps?
Joechris said:Just worried about turning one channel side upside down. Could make wireing and connections a bit confusing..?
j
Joechris said:I still think they should be the same, not even mirrored. Looks like there will be half an inch between first out and second input, so I dont think there should be any crosstalk issues.
There is also space on the pcb to move the Pout Pin points a little futher down to make even more distance.
I was, but then I saw that the tubes are flipped the other way... :`ruffrecords said:Are you concerned about heat from the tube?
mitsos said:speaking of holes, how about two more mounting holes in the center and a v-score down the middle, allowing them to break apart for single channel use?
michal_k said:I think you should check your local castorama or whatever you have in UK and perhaps include L-brackets with PCBs so that everybody has a nice fit.
ruffrecords said:michal_k said:I think you should check your local castorama or whatever you have in UK and perhaps include L-brackets with PCBs so that everybody has a nice fit.
Something like this?
http://www.diy.com/diy/jsp/bq/nav.jsp?action=detail&fh_secondid=9281752&fh_view_size=12&fh_start_index=12&fh_location=%2f%2fcatalog01%2fen_GB%2fcategories%3C{9372015}%2fcategories%3C{9372044}%2fcategories%3C{9372218}%2fspecificationsProductType%3dbrackets&fh_eds=%C3%9F&fh_refview=lister&isSearch=false
TubeUser said:Hi Ian;
thanks a lot for sharing this project with us and commenting it. I learnt new things from your comments, this is precious.
I have one thought; beginners or people who only want one channel could make it point to point and learn even more. I'm saying it because i found out it's faster and cheaper to make it p2p if it's only one channel. The same goes for psu; simple CRC or even regulator can be made p2p much faster and this way there is room for improvements, changes, customization, etc.
ej_whyte said:Where do A, B and C relate to with the EQ schematic?
