Phrazemaster
Gentlemen and gentlemen,
I know this is crazy basic, bear with me. I did well in electronics physics in High school, but that was almost 25 yrs ago! I've just ordered a basic electronics book off amazon, so I'm learning.
However, until I get myself up to speed, I'm lost with the basics.
I have a SPDT illuminated switch I will be using to power HPF and Phase circuits. I plan on using an LED and relay with the switch. After a couple of questions and posts, it's clear I can arrange this with the relay coil in series or parallel with the LED. So far so good.
It was also pointed out if I wire in series and the LED goes, the circuits won't function--a good thing I think, because a non-illuminated LED tells me either the relay coil or the LED is blown. So I thought series would be better. With me so far? I hope this is making sense.
So now it comes to actually choosing the components. I'm mystified as to how to go about picking the parts. I don't know how closely to match the voltages of the LED/relay, etc.
My noobie thinking is, get a relay and LED within similar operating specs and it should work. To that end, I've found a 4.5V relay with a coil on V of 3.38 and a current rating of 31ma. I found a white LED with 3.5Vf and 30ma operating current.
So, how do I go about knowing/deciding if this is "close enough" and will work; are there some calculations or rules of thumb to consider? Does this sound reasonable? In my beginner thinking, I can use a coil-on of 3.5V for the relay, and this matches the LED Vf. The currents are very similar at 30ma vs 31ma. So, this is a slam dunk easy? Or is there something else I'm missing? Do I need to consider the resistance of the LED and the coil as part of the circuit, and what about putting in the legendary current-limiting resistor for the LED? I hear LEDs can go thermal on you...
Seems to me I should be able to just wire these in series and they should work beautifully...whaddya think?
PS for the curious I am thinking of using this relay: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=255-1230-5-ND
with this LED: http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=160-1735-5-ND (Oh, the main page says this operates at 20ma but the spec sheet says 30ma...unless I'm misreading it)
Thank-you!
Thank-you!
