Matthew Jacobs
Hi Joel
As far as volts on capacitors go, you can always go above but never below.
So, let's say the schematic specifies 100V, it's OK to use anything above, like 200V, 400V or 600V, but not anything below like 50V.
The thing to remember is the higher the Volt rating the bigger the capacitor, so you may need to keep that in mind if space, on the PCB for example, is an issue.
J
J
