bblackwood
Active member
- Joined
- Jun 3, 2004
- Messages
- 33
The real question is - if you're listening at 90dB SPL or so, can you hear it when you stop the tape?
If so, it's too noisy, imo.
-80 still isn't great.
Obviously, something is wrong either with your clone or your measurements. So it stands to reason that there's a problem that can be fixed.
But if you insist on a 100dB S/N, why waste your time with cloning a design that's only capable of 90dB S/N on a good day?
By the way, have you measured S/N on your other pieces of gear using the Terrasonde and the same methodology? Do they all meet spec?
...and modified the vca control voltage for correkt ratios
Have you tried swapping out the opamps?
Did you use metal-film resistors?
What's the spectral distribution of the noise?
I'am not sure the terrasonde can measure these low values, or output the 22dBu needed to drive the ssl to 1% thd, so thats maybe why you get your results.
