kepeb
cheers abbey,
this is a continuation of the thread I started in the brewery,
http://www.groupdiy.com/index.php?topic=46508.0
all the links are on the first page
its a physical project and is on 'the bench' so needs to come into the lab.
I have a few more questions for the experienced tube fellas.
seems the weber design leaves some to be desired in regard to the bias voltage, any more thoughts here? why would they suggest a flawed method?
https://taweber.powweb.com/store/6o100_schem.jpg
the HT fuse is wired from the Centre tap direct to ground, how does that work to stop the flow??
do i need a special pot for the presence control as this is feeding back volts from the output?
EDIT:
here are a couple of other links i have found useful when i have questions:
http://paulrubyamps.com/info.html
http://www.duncanamps.com/technical/lvbias.html
EDIT:
