gar381
compairing the SPA-62 card (The little mini DOA) to the 17363 card DOA
the circuit is the same except for:
The SPA-62 card uses 2N2219/2N2905 output transistors
the 17636 card uses 2N4238/2N4235 output transistors
one of the transistors in the 17636 card is changed from a 2N2484
to a 2N3904 on the SPA-62 card.
Biasing diodes are bypassed with resistors in the SPA-62
and not in the 17636
Coupling caps in the SPA-62 are Tants
Coupling caps in th 17636 are Alum Electros
BTW.. 2.2uf/35v tants are on the rails of both cards
however the ones on the 17636 cards were added/modified
after thoughts.
GARY
after thoughts.
GARY
