tk@halmi
Alan,
Great observations! Thanks for your input.
1. Input pair balancing problem
If I wanted to balance the currents better in the input pair I would have added a current mirror. And I think I will do that in the next round of improvements just to reduce the output offset. Many classic designs get away without current mirrors like the Melcor 1731, API2520 and the first generation Forssell opamp. Playing with the values of the collector resistor on Q1 can help achieve balance, but it is not absolutely necessary. It does result in some 2nd harmonic distortion.
2. Output emitter follower biasing
Yes, you may want to select your diodes on the bench so you get at least 10mA going through the output all the time (I will add this to the document). It is cheaper to select the diodes than the transistors. Both the API2520 and the JH990 get away with this and they are not regarded as chopped liver in the pro-audio community. A third diode WILL eliminate the uncertainity and the excercise to swap diodes, but opens up the transistors too much and they start to heat up really fast. Perhaps two silicon and one germanium diode will be less prone to burning up the output stage.
Tamas
Build one and see for yourself :grin:PPS. I believe that D3 and D4 will not do the job you suggest....
Tamas
