Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 435
If your setup maxes out at -55dBu noise, (1mV rms) the cart is not the main issue, however the measurement is done. The problem source should be tracked with a wideband diff probe. Line freq noise from rectifiers would be high on the list of suspects. A spectrum analyzer would help greatly to find the nature of the noise. All electronics in the chain is suspect, along with wiring, power supplies, motors, or anything generating magnetic fields.
As to transformer core size, there are simple formulas for figuring this out, the core inside the carts is a clue, as is commercial offerings from Jensen and others. If transformer is placed very close to the cart, and diff wiring follows, and the noise persists, the problem is not the carts wiring, but everything after it.
I get 1mV of broadband rms noise "needle-up", at my speaker terminals with gain set for a very loud output. I stand by my measurements.
