voltage duobler for tube PSU
bigugly
Burbank, CA.
I've tried to adapt Keith's voltage doubler as used on his mic pre psu for a tube psu using a primary as a secondary. I've built it but it was a no-go. here is the schem I drew up. Does anyone see a problem?
thanks,
James
This one is simpler:
http://hyperphysics.phy-astr.gsu.edu/Hbase/electronic/voldoub.html
HTH
;Matthias
thanks,
James
This will work only if the xfmr has a center tap connected to ground
