VU Help
yodermr
Illinois
Hi, I trying to trouble shoot a LA2A I built and have traced it back to the VU meter or maybe my utter lack of understanding of VU meters.
To troubleshoot I connected the VU directly to the output of another preamp with a VU meter that I have. (Pin 2 >> + side of the VU meter, Pin 3 >> - side of the VU)
While my preamp's VU will float up and float down like a normal VU, the one on my LA2A vibrates fast around 0 % with small signals and will shoot up and shoot back down with larger ones. Best I could explain it.
The meter is a API 7045. For some reason it has its % scale on top and the db scale on the bottom. When I got it I thought it would work just the same.
Thoughts?
your meter apparently doesn't have
rectifier circuitry, which is what you need in order for it to work as a VU meter.
http://sound.westhost.com/project55.htm
Regards,
Milan
Ouch, so from a newby point of view I got some work ahead of me.
I saw this article when I was searching for answers, the simple circuit is something I could handle given a recipe of what components I need. The more complex circuit seems a bit over kill for what I need.
Any easy way to approach this?
