sonolink
Hi guys,
After a very long time (5 years) I finally finished building an AB763 (with a few mods) in a Hammond 1590BB2 enclosure. The initial idea was to use it for bass (like an Alembic F2B) but I tried it with a guitar and it sounds really good when plugged into a power amp. I also tried it as a preamp/overdrive/distortion pedal putting it in front of an amp and it also sounds great BUT a bit too thin, especially when cranking up the gain. All this is WITHOUT engaging the clipping diodes. I'm leaving these out of the equation until sorting the sound out.
I guess this thinness probably happens because the original circuit is meant to be before a power amp, not another preamp.
So my question is: is it possible (and a good idea) to add a switch that would add components in the signal path to fix that, like having a "preamp" position to use it in front of a power amp and a "distortion" position to use it in front of a preamp? If so, how would I achieve that, please?
I hope all this makes some sense
This is the schematic of my build.
Thanks for your time and help
Sono
Sono
