Hello Frank/NRG,
Any word on your quote below? Are you serious about making up some frontpanels...Or just teasing??? :wink:
Z
[quote author="nrgrecording"]
Frank, are you volunteering to do the faceplates through frontpanel express then??
Yes. OF COURSE. :wink:
Maybe a 1:1 copy AND a panel with text rotated 90° to do a 19" panel or something.
Are these 1081 values right?:
Frontpanel dimensions: 45mm x 305mm (1.75" x 8.70")
Mic gain: -80 to -10dB in 5dB steps
Line gain: +20 to -10dB in 5dB steps
HF peak / dip or shelving switch
HF at: 15, 10, 6.8, 4.7, 3.3kHz and off
HMF at: 8.2, 5.6, 4.7, 3.9, 3.3, 2.7, 2.2, 1.8, 1.5kHz and off
HMF bandwidth switch
LMF bandwidth switch
LMF at: 1200, 1000, 820, 680, 560, 470, 390, 330, 270, 220Hz and off
LF peak / dip or shelving switch
LF at: 300, 180, 100, 56, 33 and off
HPF: 27, 47, 82, 150, 270 Hz and off
LPF: 15k, 12k, 8.7k, 5.6k, 3.9kHz and off
Switch matrix for mic polarity, 48v phantom powering, eq in/out and red button for solo.[/quote]
