3 or 4 Band Fixed EQ.! ( For Tone)
Snatchman
North Carolina (USA)
Hi all. Have anyone of you designed a simple 3 or 4 band fixed EQ, that sounds really good ,just for tone control? I'm looking for one that I can use basically for tracking. Maybe with transformers. Remember, I'm no good at DIY.. :oops:.., so this will have to be assembled/complete..! Thanks ahead of time!.... :cool:
EQ basics are not difficult to understand.
http://home.online.no/~jaeioluf/sound/eqpassiv.htm
http://www.groupdiy.com/index.php?topic=16761
http://www.duncanamps.com/tsc/index.html
I made a Baxendall on breadboard easily. And breadboard is fun. :green:
[quote author="laitue5"]EQ basics are not difficult to understand.
I made a Baxendall on breadboard easily. And breadboard is fun. :green:[/quote] Hey laitue5. Thanks for the reply and links. Unfortunately, I'm just wanting to get one assembled and ready to go! If I was younger.. :roll: .., I'll give this DIY a shot. but since 'I'm over the hill" and rolling.. :green: ..I had better use this remaining time to make music while I can, than start trying to learn something that will take away from music just now! ( believe me, I tried DIY and the saying " can't teach an old dog'.. carries some weight ..in my case.. :grin: ) thanks again". Anyone with one assembled?... :cool:
I thought you were a wipper snapper..... :oops:
There is some cool gear on ebay, depending on your budget. There is a Rane parametric there at the mo that would be good buying...... also some older gear..... some expensive stuff.... Checkitout! :thumb: Maybe ask here if you're unsure which one to go for.
[quote author="mikka"]I thought you were a wipper snapper..... :oops:
There is some cool gear on ebay, depending on your budget. There is a Rane parametric there at the mo that would be good buying...... also some older gear..... some expensive stuff.... Checkitout! :thumb: Maybe ask here if you're unsure which one to go for.[/quote]Hey mikka. Unfortunately, my " whip done snapped"..... :green: ..Thanks for the info...!
Something worth checkin out is the Klangfilm KR062 eq. It is a quasi four band fix point eq. The mid band is actually a simultaneous Hi/Low mid cut/boost. If raising the high mids, it lowers the low mids. They are very effective and sound fantastic. They also have very nice make up amps inside of them.
josh
At Snatchman.... I suspect you've forgotten more than I've learned....
Re: the Klangfilm.....could you tell me some more......any hope of a schemo....?? I did a quick search but found nada...
Edit: The kids are in the bath. The bathroom is flooded, the water is running into the lounge..... and more info is here: :grin:
http://klangfilm.free.fr/index.php?lng=0&music=&type=0&frame=1&item=&title=&dir=&num=
