boji
Hello Jedi Jeff,
What's the rub on choosing to exclude switches from the cues and echos?
jsteiger said:In conjunction with individual pots? Space mostly since I didn't want to do a combo. The original single pot/4-switch array for the echo is a little cumbersome I think. It just never seemed logical to me. That's why I added to individual pots. Maybe it will be a mistake to not have switches.
I have not had any noise issues. I have used all Bourns pots and have no leakage problems either. I suppose the future pot leakage would be the main advantage to having a switch. I guess when you have 200-400 or so Cue/Echo pots, it may be easier to make sure they are all fully off with a switch. The LED is a nice touch to for a quick reference...again, if you have the room.boji said:...Any noise worries? I mean ccw is effectively short to ground, the equiv of 'off', so I dunno.
Channel Mute is relay based and is directly at the channel's input. This can be jumpered over if not wanted. More on this option later.
The same little relay circuit as I posted on your other thread. I have adapted it to a small plug-in board that I use 2 of on the VP312DI. Just couple the channels input path to ground when muting. The relay circuit works fine on either 12V or 24V, just change out the relays.boji said:What did you have in mind?
That is the only benefit since any Cues or Echos set to pre-fade would still be active with only the (On) switch. It is surely possible to remove or move one or the other. My small mind is on other projects right now. I would like to give this more dedicated thought for myself before making a concrete decision.boji said:Thanks for the reply Jeff. I'm a little confused on the reasons for having it, in addition to the (ON) switch. Is it so auxs still see signal?
Thanx boji! Everyone 'round here knows what it's like to have too many candles burning at both ends and the middle. ???boji said:Good luck on your other projects!
Notta. I just kinda like the old terms like Cue and Echo instead of Send/Aux/Foldback or what have you not.btw what's the difference btw an echo and an aux? ???
jsteiger said:Call me weird but I also prefer the full Direct Inject over the DI abbreviation.
