ledogboy said:
...one thing I didn't see much about (or I missed due to the large volume of info I was processing) was what your plans are for a center section. If you have any thoughts on that, I'd be very curious...
Without a doubt, the most involved and comprehensive part of the project. This is down the road a ways but here are excerpts from my notes that I have been compiling.
--Subgroup Masters (ACA->level control->325 style booster)
-Level control, preferably fader, worst case pot(real estate?)
-Pgm assign, either left switch & right switch or preferably signal switch with pan-pot
-Solo
--Echo Send Masters (ACA)
-On/Off select
-Level pot
--Stereo Master Cue Module
-Solo
-Source select
-Pgm L/R, Cue 1/2, Echo 1/2
-Output level control pot
--Mute Group control
-Simple mute/active pushbutton switch for each mute group
--Solo Master
-Level
-LED indication
--Talkback
-XLR mic in (hopefully front panel)
-Level control pot
-Slate to Subgroups (pushbutton)
-Slate to Pgm (pushbutton)
-T/B to Master Cue (pushbutton)
-T/B to All (pushbutton)
--Control Room Module
-C/R Level, big ass knob, stepped switch (or pot)
-Dim pushbutton & dim level pot
-C/R cut pushbutton
-Monitor select
-Big
-Small, with level pot
-Mono
-C/R Source Select (4 options)
-Pgm (2-Mix)
-2 track A
-2 track B
-2 track C
--Pgm 2-Mix stereo fader (2-ACA-Bo circuit)
Of course this is all preliminary but the goal so far. Not everything would be required but will probably have a dedicated spot on the center section motherboard for the above. It will probably be broken into 2 motherboards which will take up (2)-8 space 400 series buckets. The 400 series faceplate is the same as the 500 but the PCB will be nearly 1” less deep at 5”. That will match the depth of the main Input Module, Subgroup/Echo module and dual Echo Return module.
I have a new input module I am working on that will be fully inclusive. Meaning that it will have a level control pot (can be internally jumpered to use a separate fader), 2 Cue sends, 2 Echo sends, panpot, 2-Subgroup assigns, Pgm assign, vintage style HP filters, solo, on & polarity. The Cue and Echo’s each have a pre/post fader select switch plus each send is on it’s own pushbutton to activate it. All of this stuff in a single 500 series sized module. My goal is to have as many features as possible in this one module, so this one module is all that is needed to make this console functional. A full throw fader can be used but not required. Also, I have an additional Subgroup/Echo send module that can be added which will give 6 more Echo sends and 10 additional Subgroups and an optional balanced direct out.
I have been busy on this!
Cheers, Jeff
