bcarso
syn, if you have the tools to draft them you might consider showing a before and after schematic---it would be instructive for people learning troubleshooting. Just a thought.
- Uses easy to obtain BJTs
D7 or the according resistor should not be changed as it would change the collector current of Q2 as well which might have other implications. The other diodes don't offer any suitable change either (besides selecting them for low diode drop, but the 1N914B are pretty consistent so little to be gained from here). You could increase the emitter resistors R7/R8 a bit--increase the value in small steps (say 12, 15 and 18 Ohm) and observe the quiescent current.Is there an adjustment you'd suggest for the current-setting resistor/diode (D7) or diodes D1, D2, D5, D6 to lower idle current down to 20-25 mA to keep the opamp cooler?
IIRC the version without darlingtons showed better stability.Is there a benefit to NOT using the darlington transistors (also based on my not needing maximum output current)?
Thermally coupling the diodes D1, D2, D5 and D6 pairwise to an output transistor will lower the quiescent current so this might be beneficial here.There was a lot of discussion about thermal connections between darlingtons (insulated bond to each other) and/or diode-transistor coupling. Is there a consensus about whether and what to couple if anything?
Here is a link to the latest documentation and the evolution of the Bloaks:
{Link that's no longer alive}
It includes drawings for:
- GainBloak
- FetBloak (2SK170BL input)
- Improved FetBloak (more stable VAS)
- The BigBloak (Darlington output transistors)
The latest one uses the MJE800/700 darlingtons. This reduces distortion by 75% through improved open loop gain, and drives impedances down to 75 ohms... This one really consists of eight transistors, but it uses the same PCB as all the others.
I am ready to order parts for a couple of FET (maybe BIG) bloaks. They'll be used in API-like mic pre
